Examining Workflows
You can use the Workflows tab to view the different workflows that the selected workflow BP might be used in. You can drill down through a workflow and look at the steps involved using different presentations. You can also review the information available for each step, such as the corresponding status for a BP record.
To examine the workflows of a BP:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select System Information, and then select BP Visualizer.
- Click a BP.
- In the BP Visualizer [BP Name] window, select the Workflows tab.
- In the list of workflows, click Data Workflow
for the one that you want to view. - To return to the list of BPs, click Show BPs
in the upper-left corner.
Last Published Tuesday, April 15, 2025
