Examining References
You can use the References tab to view the all the links within a BP and between the selected BP and others.
To examine the references of a BP:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select System Information, and then select BP Visualizer.
  3. Click a BP.
  4. In the BP Visualizer [BP Name] window, select the References tab.
  5. Use the various options, such as Layout, to change the display.
  6. To return to the list of BPs, click Show BPs in the upper-left corner.
Last Published Tuesday, April 15, 2025
