Updating the Data Structure Setup
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Data Structure Setup, select Data Definitions, and then select Basic.
- Locate and update the UE rep_Report_SPD data definition to activate or add the report name on the Data Set tab.
- In the left Navigator, select Data Structure Setup, select Dynamic Data Sets, and then complete the following to update the Report Utility dynamic data set:
- Locate and open the config_vs_rep_LI_ReportSPD dynamic data set.
- From the toolbar, click New option to add rows for the search parameters of the report you intend to print with the Report Utility BP.
The search parameters can be seen on the custom report at run-time or in the Query tab of the Custom Template Report setup.
Note: These are search parameters for the existing custom report that you are using as a model for the custom print; these are not search parameters for the new custom print.
See Also
Configuring and Generating Custom Reports using the Report Utility BP
Setting Up the Custom Print Custom Template
Setting Up the Report Utility BP
Last Published Tuesday, April 15, 2025
