Assigning Access Control for Administrators of Company Information and Company Settings
To set permissions for administrators of the Company Information node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the right pane, expand Administration Mode Access, and then expand Company Information.
- In the Permission Settings for: Company Information dialog box, use the Add, Modify, and Remove options to make the applicable changes.
For example, you can add users and groups. For the Company Information node, you can assign the Modify permission, which automatically grants the View permission. For the Company Settings node, you can assign the Modify permission, which automatically grants the View permission, or assign only the View permission.
Note: The Company Information node assigns View permission for all users by default.
See Also
Last Published Tuesday, April 15, 2025
