Manage Support and eLearning Contact Information (Contact Tab)
In the Contact tab of the Edit Company window, you can provide your users with an email address and/or phone number of your internal support staff. This information will be displayed in error messages users may encounter if their accounts become locked, on the Support window Contact tab, and at the bottom of email notifications. The information included for email notification can contain a hyperlink to your local support. For information about translating Email Notifications, see the Internationalization (Email Notifications) section.
In addition, if your company is part of the eLearning suite of interactive tutorials, you can provide access information to your users in this tab. This space can also be used for any location (such as an internal website) where you have provided Unifier Essentials training materials.
To manage user support contact information:
- Go to the Company Workspace tab and switch to Admin mode.
- In the right pane, click the Open button. The Edit Company window opens.
- Open the Edit Company window and click the Contact tab.
- Under Support Contact Info and eLearning Access, you can add or modify the contact information as needed. See the following table for details.
- Click Apply to save changes, or OK to save and exit the Edit Company window.
To complete this section: | Enter this information: |
Support Contact Info | Email: Email address for company internal support. Phone: Phone number for company internal support. Instructions: Information that appears in the Support window Contact tab, as well as the Email and Phone from above. This provides information to your users on how to use the support information. Email Notifications: Information that appears at the bottom of email notifications. This field supports simple html formatting, and can include a hyperlink. For example: <p>For YourCompany support, contact <a href="mailto:support@yourcompany.com">support@yourcompany.com</a> or 1-800-555-1212. </p> which will display in the bottom of record email notifications as: For YourCompany support, contact support@yourcompany or 1-800-555-1212. |
eLearning Access | URL: Enter the URL for eLearning access. It is best to include the entire address Label: This is the label for the URL above. The label can display the actual URL, or you can a different label. This will appear as a hyperlink to users. Contact email: Enter an email address that you would like users to use if they need to contact someone. Enter a valid email format, for example, elearn@yourcompany.com. Instructions: You can enter instructions or other information such as a contact phone number. This field does not support html formatting. |
Last Published Tuesday, June 4, 2024
