Adding and Managing Partner Companies
An Owner Company (also referred to as a Sponsor Company) may work with one or many Partner Companies (for example, subcontractors, vendors, and so on) to work on shells or company-level activities. Company Administrators can manage Partner Companies and users. (Depending on your environment, your Oracle Cloud Administrator might need to add the users.) You can grant Partner Company users access to specific company-level and shell-level features.
When a Partner Company user is added to a shell, the system verifies that the user's company is a Member Company; if not, the system adds the Partner Company. When a Partner Company is removed from a shell, the Partner Company users are automatically set to Inactive.
To access the Partner Companies page:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Partner Companies.
The Partner Companies page is displayed. Before the first Partner Company is added, the page displays Add your first partner company and an Add button.
After at least one company is added, the page displays two panes. The left pane displays a list of the current Partner Companies available in the system, while the right pane displays more information about the company selected in the left pane.
At the top of the left pane, you can use the Search option to find a company in the list by using its name. You can filter the list using the Active, Inactive, and Location options, and you can use Sort By to sort the list in ascending or descending alphabetical order.
If you have the applicable permissions, you can add Partner Companies, update their information, and change their status.
You can use the Audit Log to view a record of changes made, the date the change was processed, and the name of the user that made the change. The system also lets you search through and print the log.
In This Section
Updating Partner Company Information
Removing (Deactivating) a Partner Company
Reactivating a Partner Company
Viewing a Partner Company Profile
Last Published Tuesday, April 15, 2025
