Exporting User Records
You can export a CSV file with current user information.
To export a CSV file containing all user records:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Company Users.
- From the File menu, select Export, and then select All.
Depending on your browser, the CSV file will be automatically downloaded or you will be prompted to download it manually.
To export a CSV file containing selected user records:
- In the Company Users log, select one or more users to export (press the Ctrl or Shift keys to select multiple users).
- From the File menu, select Export, and then select Selection.
Last Published Tuesday, April 15, 2025
