Managing a User's Group Membership (Groups Tab)
You can manage a user's group membership from the Groups tab of the Edit User window. This tab displays all the groups that the user is a member of and lets you quickly add or remove groups. For information about adding or managing groups, see Adding and Managing Groups.
To add a user to a group:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration.
- Depending on the type of user, select either Company Users or Partner Users.
- In the Users log, select a user and click Open.
- In the Edit User window, select the Groups tab and click Add.
- In the User/Group Picker, select the Group and click Add.
- After the group appears in the Selected Users/Groups section, click OK to save your changes.
To remove a user from a group:
On the Groups tab, select a group and click Remove.
Last Published Tuesday, April 15, 2025
