Changing the Status of Multiple Company Users
If you want to change the status of multiple users at the same time, you can select the users from the log and change the status for all those users. This eliminates the need for you to open each user record to modify the user status.
The License Manager controls the number of active users within a system.
To change the status of multiple company users:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Company Users.
  3. Select the users whose status you want to change.
  4. Choose Status and one of the available statuses (Active, Inactive, On-Hold).
Last Published Tuesday, April 15, 2025
