Change User Group Assignments or Add New Users in Bulk
To add or remove user group assignments in bulk:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Company Sponsored Shells, and then select the applicable shell log (for the shells that you have configured).
  3. Open the shell from the log.
  4. In the left Navigator, select User Administration, and then select Groups.
  5. In the Groups log, double-click the group that you want to assign users to.
  6. On the Members tab, click Add to open the User/Group picker.
  7. Select the user(s) to add to the group and click Add to move users to the Selected Users/Groups list. Use Ctrl+Shift to select multiple users simultaneously.
  8. Click OK when finished.
To add new users to a shell in bulk:
  4. In the left Navigator, select User Administration, and then select Users.
  5. Click New to open the User/Group picker.
    The Users/Groups are listed based on the company selected in the List Names from list at the top of the window.
  6. Select the user(s) to add to the group and click Add to move users to the Selected Users/Groups list. Use Ctrl+Shift to select multiple users simultaneously.
  7. Click OK when finished.
Last Published Tuesday, April 15, 2025
