View Update Users History
The History log, which is accessed through the Update Users option, shows the list of the selected users, including the Partner users, and the status of the user preference update for those users. You can view additional details about previous Update Users runs.
To view Update Users History:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Standards & Libraries, and then select User Preference Templates.
The Preference Template log opens.
- From the toolbar, click Update Users, and then select History.
The Update Users: History window lists the following:
- Requestor: User who initiated the update process.
- Users: Displays all company sponsored users selected (either the selected users or all users).
- Submit Date: When the update request was submitted.
- Start Date: When the update process began.
- End Date: When the update process finished.
- Status: Status of the request.
- Select an instance from the list and click Open (or double-click to open).
The History Details window indicates which users were updated by the request, the name of the template that was used, and a list of the attributes that were updated.
- When you are done, click Close and then click Close Window.
Last Published Tuesday, April 15, 2025
