Cancel a User Update Request
You can cancel an update request that has not started, that is, the status is not In Process or Finished.
To cancel a user update request:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Standards & Libraries, and then select User Preference Templates.
    The Preference Template log opens.
  3. From the toolbar, click Update Users, and then select History.
  4. In the Update Users: History window, select an update that has not started.
  5. From the toolbar, click Cancel Request.
  6. When you are done, click Close Window.
Last Published Tuesday, April 15, 2025
