Edit User or Group Permissions Using Access Control
To adjust permission settings using Access Control:
  1. Do one of the following:
    • To open company-level access control, go to the Company Workspace tab and switch to Admin mode. In the left Navigator, select User Administration, and then select Access Control. The Access Control window opens in the right pane of the Unifier Essentials window. The window displays a copy of the Navigator.
    • To open access control for a project or shell, go to the shell tab and switch to Admin mode. In the left Navigator, select Access Control. The Access Control window opens in the right pane of the Unifier Essentials window. The window displays a copy of the Navigator.
  2. Select a module in the Access Control window. The Module Permission Settings window opens. It lists the user(s) and group(s) that currently have access to the selected module and their permission settings.
You can Add, Modify, or Remove users or groups, and grant permission levels. See the following procedures.
To add user and group access to a module:
  1. From the Module Permission Settings window, click Add. The Permission/Access Control window opens.
  2. Click Add Users/Groups. The User/Group Picker opens.
  3. Select users or groups from the list, click Add to add them to the Selected Users/Groups list, and click OK.
  4. In the Permission Settings window, select the level of permissions you want to assign to the Users/Groups. Click OK.
To remove a user or group and their related module permissions:
In the Module Permission Settings window, select the checkbox next to the user or group and then click the Remove button.
To modify permission settings:
In the Module Permission Settings window, select the checkbox next to the user or group and then click the Modify button. Make changes to permission settings as needed and click OK.
Last Published Tuesday, April 15, 2025
