View License Manager Terms and Usage
The License Manager console provides easy access for viewing license terms and usage.
To view the License Manager console:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select General Administration, and then select License Manager.
The License Manager console opens in the right pane. Depending on the licensing purchased by your organization, you might see the following:
- Standard Users: This block is always displayed and provides the total license count for Company and Partner users.
- Portal Users: This block is displayed when the environment has license-count of portal users greater than zero.
- Collaborator Users: This block is displayed when the environment has license count of collaborator users greater than zero.
- Earned Value Management Users: This block is displayed when the module is loaded.
Each block has the following information:
- License Terms: Displays the number of Active Named Users — that is, any user with a specific user name and password — in the sponsor company and all partner companies. ("Active" refers to users with a status of Active or On-Hold.)
- Current Usage: Displays the current number of Active Named Users (users with status Active or On Hold for your company and partner companies. Usage refers to user records only, regardless of whether the users are currently signed in. (Current Usage also displays the "as of" date and time of the last update.)
To view the License Terms window:
The License Manager console displays in the right pane.
- In the upper-right corner, click Settings
and select License Terms.When you edit the user count, you enter a combined number for active named users.
- The General tab displays your company's current license terms. This tab is read-only, and managed by the Site Administrator (Oracle Cloud Administrator).
- The Notifications tab lets you schedule regular usage checks and configure thresholds for notifying you when you are getting close to license term limits.
Last Published Tuesday, April 15, 2025
