View or Print the License Manager Audit Log
The audit log captures changes made to license terms. You can view the audit log, search for specific changes, print a copy, or save a PDF copy to your local drive.
To view or print the Audit Log:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select General Administration, and then select License Manager.
The License Manager console appears in the right pane.
- In the upper-right corner, click Settings
and select Audit Log.The Audit Log opens. You can scroll through the list of events, sort the list by clicking the applicable heading, or click the Find on Page button to search for a specific entry.
- To view a record's detail, which includes for reference the current time zone of the user viewing the audit log, double-click a listed event.
- To print or save the log, click the Print button, and then select the applicable output option after the PDF file is created.
Last Published Tuesday, April 15, 2025
