System Usage Report Types
The following describes details for running the predefined system usage reports.
Usage Detail By Company
This report lets you view usage times across a company and all its partner users grouped by Company /Partner name. This report uses the login time to track usage and shows usage per day (not per session).
The report results are sorted as follows:
- Company name in alphabetical order
- For each company, the list of user names: first name, last name
- For each user, lists the source alphabetically
- When source = Project, project names are listed alphabetically
Report Query Parameters:
- Owner Company: Read-only
- Source: All, Company Workspace, Project/Shell, or Other
- Project/Shell: Select a project or shell or leave blank
- Partner Company: Select a partner or leave blank for all
- Date Range From
- Date Range To
This column: | Shows: |
Company Name | The name of the company for which the report is being generated. Depending on filter condition, this report can be generated for a particular company or all. |
User Name | The user names that are involved either in projects and shells or directly at Company level. |
User ID | The user IDs that are involved either in projects and shells or directly at Company level. |
Source | Company Workspace, Project, Shell, or Other |
Name | The names of projects and shells that have users assigned to it either from Company or Partner levels. If user does not participate in any projects or shells the Project or Shell Name and number columns are empty. |
Number | The number that corresponds to the project or shell Name |
Date | Date when user signed in |
Usage (Min) | Time taken by User in minutes between sign in and sign out |
Usage (Hrs) | Time taken by User in hours between sign in and sign out |
Total | Total time taken by all users per company login level and per Company Partner level |
Grand Total | Total time taken by all users at a company level as well as Company Partner level |
Usage Summary By Company
This report lets you view summarized usage times across the sponsor company and partner companies. These are usage times logged by users, after they sign in, independent of whether they are working for their own company or other companies. The report results are sorted alphabetically by company name.
- Project/Shell: Select a project or shell or leave blank for all
- Date Range From
- Date Range To
Company Name | The company name. Depending on filter condition, this report can be generated for a particular company or all companies. |
Usage (Min) | Total Time taken by all Company Users in minutes at "Source" level between sign in and sign out in the specified date ranges |
Usage (Hrs) | Total Time taken by all Company Users in hours at "Source" level between sign in and sign out in the specified date ranges |
Usage Detail By Project/Shell
The Usage Detail By Project/Shell report shows usage details per projects and shells across a company and its partners grouped by project or shell name. Results are sorted by:
- Project and shell names alphabetically for all projects belonging to user company
- For each project or shell, lists users belonging to owner company first followed by partner company sorted alphabetically
- Within a company, users are sorted alphabetically by first name, last name
- Source: defaults to Project/Shell
- Date Range From
- Date Range To
Name | The names of projects and shells that have users assigned to it either from Company or Partner levels. |
Number | The corresponding Project and Shell Numbers. |
Company Name | Name of the owner company. Depending on filter condition, this report can be generated for a particular Sponsoring company. If no users from current company are assigned to the Project, the row will start with Partner name. |
User Name | The user names that are involved in projects or shells |
User ID | The user ids that are involved either in projects or shells |
Usage (Min) | Time taken by User in minutes between sign in and sign out working on that project or shell |
Usage (Hrs) | Time taken by User in hours between sign in and sign out working on that project or shell |
Total | Total time taken by sponsor company or partner company users for a given project or shell |
Grand Total | Total time taken by sponsor company or partner company users across projects or shells. |
Usage Summary By Project/Shell
This report displays summarized usage times per project and shell across a company and partner users grouped by project name.
- Date Range From
- Date Range To
Name | The names of projects or shells that have users assigned to it either from Company or Partner levels |
Number | The corresponding Project and Shell Numbers |
Company Name | Either the Sponsoring Company Name or Partner Company Name. Distribution across Owner Company and Partner users in a given Project |
Usage (Min) | Total Time taken by all Users in minutes between sign in and sign out per project or shell |
Usage (Hrs) | Total Time taken by all Users in hours between sign in and sign out per project and shell |
Total | Total time taken by users at a company level as well as Company Partner level for across all company projects or shells |
Usage Detail By Company Workspace
This report displays usage times for company and partner users working in the owner company's Company Workspace.
- Source: defaults to Company Workspace
- Project/Shell: Not applicable
- Date Range From
- Date Range To
Company Name | The company name. Depending on filter condition this report can be generated for a particular Sponsoring company. If no users from current company are assigned to work in the Company Workspace the row will start with Partner name. |
User Name | The user names that are involved at Company Level |
User ID | The user ids that are involved at Company Level |
Usage (Min) | Time taken by User in minutes between sign in and sign out working at the Company Workspace |
Usage (Hrs) | Time taken by User in hours between sign in and sign out working at the Company Workspace |
Total | Total time taken by users at a company level as well as Company Partner level at Company level |
Grand Total | Total time taken by users at a company level as well as Company Partner level across Company and its Partners. |
Usage Summary By Company Workspace
This report summarizes usage times for company and partner users working in the owner company's Company Workspace.
- Date Range From
- Date Range To
Company | Name of the Sponsoring Company or Partner |
Usage (Min) | Total Time taken by all Users in minutes between sign in and sign out in Company Workspace per Company/Partner |
Usage (Hrs) | Total Time taken by all Users in hours between sign in and sign out in Company Workspace per Company/Partner |
Total | Total time taken by users at the owner company level as well as Company Partner level in the Owner Company Workspace |
Usage Detail By User
This report details usage across a company and all its partner users grouped by user name. The results sort by user's first name and last name independent of whether user belongs to the owner company or a partner company.
- Date Range From
- Date Range To
User Name | The user names that are involved either in Projects or directly at Company Level |
User ID | The user ids that are involved either in Projects or directly at Company Level |
Company Name | Company Name of the User |
Source | Either Company Workspace/Project/ Other |
Name | The names of projects and shells that have users assigned to it either from Company or Partner levels. This column is empty if Source is Company Workspace or Other. |
Number | The corresponding Project or Shell Numbers. This column is empty if Source is Company Workspace or Other |
Total | Total time taken by a particular user at a company level as well as Company Partner level across Source criteria |
Grand Total | Total time taken by all users at a co. level as well as Company Partner level across Source criteria |
Usage Summary By User
This report displays summarized usage times per user. The report is sorted alphabetically by user first name, last name.
- Date Range From
- Date Range To
User Name | All user names for sponsor company and partner companies |
User ID | The corresponding User IDs |
Company Name | Each user's company |
Usage (Min) | Total Time taken by a user in minutes between sign in and sign out summed up in the date ranges |
Usage (Hrs) | Total Time taken by a User in hours between sign in and sign out summed up in the date ranges |
User Account Details
This report displays account status details across a company and partners grouped first by Company User Names and then Partner User Names.
- Source: All, Company Workspace, or Projects/Shells
- Source Name: Active if Projects/Shells is the source. Click Select and select the project or shell name from the list.
Company Name | The Sponsor Company Name, followed by the Partner Names |
User Name | All user Names from a company and partner users assigned to Sponsoring Company Projects |
Source | The Project or Shell Name the user is a part of |
Source Name | The name of the project or shell |
Date Added | The date that this user was added to the company. This column is empty for Partner users |
User Status | The Status of the User at the project or shell level whether (Active/Inactive) |
Status Effective Date | The date the Status of the user changed at the project level. |
User Account Summary
This report summarizes account status details across a company and partners grouped first by Company User Names and then Partner User Names.
Company Name | The Sponsoring Company or Partner |
Company Short Name | The short name for the Company |
Total Users | Total number of users at Owner Company/Partner working on Owner Company Workspace or Owner Company Projects |
Current Active Users | Total number of active users at Owner Company/Partner working on Owner Company Workspace or Owner Company Projects |
Current Inactive Users | Total number of inactive users at Owner Company/Partner working on Owner Company Workspace or Owner Company Projects |
Current On Hold Users | Total number of inactive users at Owner Company/Partner working on Owner Company Workspace or Owner Company Projects |
User Session Detail
This report displays user sign-in session details.
- Owner Company
- Date Range From
- Date Range To
- Platform
- Website
- Mobile App
- Website & Mobile App
User Name | All user Names from an Owner Company |
Login Date | Date user signed in |
Logout Date | Date user signed out. (Dates will displayed in Server Time zone) |
Session End Type | Timeout or Logout |
Usage (Min) | Usage between sign in and sign out in minutes |
Usage (Hrs) | Usage between sign in and sign out in Hours |
Total | Total time taken |
The following shows the columns according to the platform:
Website | As is. |
Mobile App | Output for User Session Detail Report: The header of the Report will have the fields of Owner Company, Partner Company, Report Run by, and the date that the report was run on. Columns displayed in the report output:
Website & Mobile App | Output for User Session Detail Report: The header of the Report will have the fields of Owner Company, Partner Company, Report Run by, and the date that the report was run on. Columns displayed in the report output:
About Platform
Unifier Essentials can be accessed through various platforms (website, mobile app, or both), and you have the option to track the users when they sign in through these platforms. This ensures that you can capture information such as number of sign-ins, device type, and so forth.
When you select the platform, the report output, will have the following columns:
Operating System | The version of the device operating system. |
Device | The device model. For example, Apple iPhone 7 plus. |
Website | As is. |
Mobile App | Output for Last Login Report: The header of the Report will have the fields of Owner Company, Partner Company, Report Run by, and the date that the report was run on. Columns displayed in the report output:
Website & Mobile App | Output for Last Login Report: The header of the Report will have the fields of Owner Company, Partner Company, Report Run by, and the date that the report was run on. Columns displayed in the report output:
The information above applies to the following reports (which are available by going to the Company Workspace tab, switching to Admin mode, and selecting System Reports in the left Navigator):
- User Session Detail
- Last Login
- Current Login
The available report formats are:
- HTML
- CSV
- Excel
- XML
Last Login
This report displays last sign-in details for a user. It lists the users that have signed in, not all user accounts. If a user has never signed in, that user will not be listed on the Last Login Report.
- Platform: Select a platform to monitor.
User Status | The status of the user |
Last Login Date | Date when Company User last signed in. For a partner user, this date should be the last date the user signed in to Partner Company Workspace. |
Days Since Last Login | Number of days since the user last signed in. Calculated as difference between last sign in date and the date on which the report is run. |
Current Login
The Current Login Report displays currently logged in users.
- Source Name: Active if Projects is the source. Click Select and select the Project name from the list.
- Partner Company: Select a partner or leave blank for all.
Company | Sponsor company |
User Name | All user names from an Owner Company |
Source | The source |
Source Name | The source name |
Source Number | Corresponding number |
Login Time | Login time for the current session |
Remote Address | The IP address of the computer from which the user is logged on |
Website | As is. |
Mobile App | Output for Current Login Report: The header of the Report will have the fields of Owner Company, Partner Company, Source, Source Name, Report Run by, and the date that the report was run on. Columns displayed in the report output:
Website & Mobile App | Output for Current Login Report: The header of the Report will have the fields of Owner Company, Partner Company, Source, Source Name, Report Run by, and the date that the report was run on. Columns displayed in the report output:
Proxy Login
This report displays user sign-in proxy details.
- Partner Company: Select a partner or leave blank for all partners
- Date Range From
First Name | The Proxy first name |
Last Name | The Proxy last name |
Login User Name | The user who logged in |
Company Short Name | The Company name of the Proxy user |
Proxy User Name | Then name of the Proxy |
Login Date | The date the user logged in |
Last Published Tuesday, April 15, 2025
