This manual is designed to help acquaint you with the Job scheduling process in Oracle FLEXCUBE.
This manual is intended for the following User/User Roles:
| Role | Function |
| Back office data entry Clerks | Input functions for maintenance related to the interface. |
| Back office Managers/Officers | Authorization functions. |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
| Abbreviation | Description |
| System | Unless and otherwise specified, it shall always refer to Oracle FLEXCUBE system |
This manual is organized as follows:
| Chapter | Description |
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
| Chapter 2 | Job Scheduling explains about the process of defining, scheduling, and maintaining Jobs within the module. |
| Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons.
| Icons | Function |
 | Exit |
 | Add row |
 | Delete row |
 | Option List |
