Construction Intelligence Cloud Analytics Administration Application Overview
CIC Analytics is managed using the CIC Analytics Administration application. The administration application allows you to configure and manage users, and CIC Analytics data sources for your organization.
The following applications can be used as data sources in CIC Analytics:
- P6 EPPM
- Primavera Unifier
- Primavera Cloud
- Oracle Aconex
This document describes how to administer CIC Analytics by accomplishing the above tasks.
Administrator Privileges
As a CIC Analytics administrator, you can:
- configure data sources from the above source applications
- run initial loads, ODI loads, and schedule ETLs for each data source
- add users as analytics consumers and analytics creators
- create custom groups and assign users to these groups
- manage user's privileges to access specific data sources
Managing CIC Applications Suite
If your organization is also provisioned with CIC Advisor, then you can use the administration application to also manage CIC Advisor. For more details, see the CIC Advisor Administration Guide.
With access to both the CIC applications, you can create Suite administrators and analytics administrators. For more details, see Managing CIC Suite Users.
Intended Audience
Cloud administrators responsible for managing CIC Analytics should use this document.
Last Published Friday, March 7, 2025
