Setting Up Source Applications for CIC Analytics
This administration guide is meant for CIC Analytics administrators who manage data displayed in CIC Analytics from any of the following source applications:
Setting Up P6 EPPM for Analytics
If you plan to use CIC Analytics for P6 projects, then configure and publish your P6 EPPM projects to bring data into CIC Analytics.
For more details see Construction Intelligence Cloud Analytics P6 EPPM Application Setup Guide.
Setting Up Primavera Unifier for Analytics
If you plan to stage Primavera Unifier data in CIC Analytics then configure analytics settings in Unifier to bring data into CIC Analytics.
For more details, see the Construction Intelligence Cloud Analytics Primavera Unifier Application Setup Guide.
Setting Up Oracle Primavera Cloud for Analytics
No specific settings need to enabled to publish Primavera Cloud data in CIC Analytics.
Setting Up Oracle Aconex for Analytics
Identify and enable project fields in Aconex that are to be made available in CIC Analytics. Only the Enabled project fields will be picked up by the ETL process in CIC Analytics.
Last Published Friday, March 7, 2025
