Creating CIC Analytics Only Users
Use this procedure if you want to add a new user who has not been ported from any source application. Users of this category will automatically have access to CIC Analytics.
- Use any of the following methods to sign in to the administration application:
- In your Welcome email, click on the CIC Analytics administration application URL and sign in with administrator credentials or
- Sign in from the Primavera Administration Application portal and click on the Administration application URL.
https://<host>:<port>/p6rdb
- In the side bar, click
User Management.The following message displays: Sync in in progress, please wait. Once sync is completed, the following message displays: <n> users synced,
where n is the number of users synced. - Click the All Users tab to view a list of existing users from the following source applications who have been ported into CIC Analytics:
- P6
- Unifier
- Primavera Cloud
- In the Search bar, enter or search for a user by their user name or email and click Search.
- If the user does not exist click Create an account to create an identity management account for this new user.
- In the Create User pane, enter the following contact information of the user:
- In the Last Name field, enter the last name of the user.
- In the First Name field, enter the first name of the user.
- In the User ID field, enter the user name that the user will use to sign in to the CIC Analytics application.
- In the Email field, enter the user's email ID that is to be associated with their User ID.
- In the Mobile field, enter the primary phone number to contact the user.
- In the Datasource section, select the corresponding check box to give the user access to all data brought into CIC Analytics from the selected data sources.
- Caution: Judiciously assign users of this category in your organization as they will have access to all data from the source applications in CIC Analytics.
- Click Create to add the new user.
The user will be assigned the role of an Analytics Consumer by default. To change the user's role, see Enabling CIC Analytics User Access.
Related Topics
Last Published Friday, March 7, 2025
