Assigning Groups For Unmatched Users
When you select
User Management in the sidebar, users are synched between the between the CIC administration application and Primavera Cloud portal. Users whose roles cannot be associated with any group in CIC, are classified as Unassigned by default. You will need to manually assign these users to a standard or custom group.
To assign a group for unmatched users:
- In the side bar, click
User Management.The following message displays: Sync in in progress, please wait. Once sync is completed, the following message displays: <n> users synced,
where n is the number of users synced. - In the Assign Users dialog:
- Click Select a group in the Group column, and choose a group from the drop-down list.
- Select the check box to confirm your selection.
- Repeat the above step for each user.
- Click Save to confirm your selections.
Related Topics
Assigning Users to Custom Groups
Last Published Friday, March 7, 2025
