Creating Custom Roles
Custom roles can be created by Suite administrators and Analytics Administrators. If your organization is provisioned with CIC Analytics and CIC Advisor, CIC Advisor administrators can only view custom roles.
To add a new custom role:
- Use any of the following methods to sign in to the administration application:
- In your Welcome email, click on the CIC Analytics administration application URL and sign in as a Suite administrator or CIC Analytics administrator or
- Sign in from the Primavera Administration Application portal and click on the Administration application URL.
https://<host>:<port>/p6rdb
- In the side bar, click
User Management, select the Roles tab, and then click Add New Role. - In the Role Name field, enter a unique name for the custom role.
- In the Description field, enter a short description about the purpose of the role.
- Click Save.
When the custom role is created successfully, the role Status displays Created.
- Note: Custom role creation takes approximately 70 minutes, depending on the number of roles queued up for creation.
- Proceed to create groups with custom roles.
Related Topics
Adding Users With Custom Roles
Last Published Friday, March 7, 2025
