Configuring P6 Codes for Each Data Source
To extract and load P6 EPPM codes:
- Sign in to the CIC Administration application from the Cloud Landing page of the Primavera Administration Application provided in your Welcome email.
http://<host>:<port>/cicadmin
- In the Home menu, select a staretl<id> or a <Custom Name of a data source>.
- In the left pane, select
Codes. - To migrate codes for the selected P6 data source, select any of the following tabs:
- Project
- Activity
- Notes:
- A maximum of 240 codes is supported for each area (Project, Activity, and Resource).
- By default, only those codes that have been enabled through the CIC Administration application are exposed in the subject areas.
- To select codes for migration:
- From the Available Codes list, select one or more P6 codes.
- Select Move Right.
- To deselect codes from being migrated:
- From the Enabled Codes list, select one or more P6 codes you want to remove.
- Select
Move Left.
- Select Save.
Related Topics
Configuration Settings for P6 EPPM Data Source
Configuring P6 UDFs for Each Data Source
Last Published Friday, March 7, 2025
