Diameter Maintenance and Status Data for Components, DSR Applications, and DA-MPs
- Route Lists Maintenance – The screen displays information about the Route Groups assigned to Route Lists. Route List maintenance and status data is maintained and merged to the OAMs. The data is derived from the current Operational Status of Route Groups assigned to a given Route List. The Operational Status of each Route List determines whether the Route List can be used for egress routing of Request messages.
- Route Groups
Maintenance – The
screen displays the configured and available
capacity for Route Groups and displays information about Peer Nodes or
Connections assigned to a Route Group.
This information can be used to determine if changes need to be made to the Peer Node or Connection assignments in a Route Group in order to better facilitate Diameter message routing. Additionally, this information is useful for troubleshooting alarms.
Policy and Charging will create and add one metadata record to the TTR for each event that occurs while any Diameter message in the transaction is being processed. This function is achieved through Policy and Charging support of IDIH.
- Peer Nodes Maintenance – The screen provides the Operational Status of Peer Node connections, including a Reason for the status.
- Connections
Maintenance – The
about existing connections, including the Operational Status of each
connection.
The screen displays statistics about paths within an SCTP connection. Each line on the screen represents a path within an SCTP connection.
- Applications
Maintenance – The
screen displays status,
state, and congestion information about activated
DSR
Applications. The data is refreshed every 10 seconds.
On the screen, you can change the Admin State of the selected DSR Application to Enabled or Disabled.
- DA-MPs
Maintenance – The
screen provides state and
congestion information about Diameter Agent Message Processors.
On the screen,
- The Peer DA-MP Status tab displays Peer status information for the DA-MPs.
- The DA-MP Connectivity tab displays information about connections on the DA-MPs.
- The tab for each individual DA-MP displays DA-MP and connection status from the point-of-view of that DA-MP.
The screen displays the Message Processor (MP) SCTP statistics per MP, for all MPs or for a selected set of MPs. Each row shows the statistics for one MP.
Diameter Maintenance is described in more detail in the Diameter User Guide and in the Diameter Help.
