Complete the following steps to convert an SDEF file to an XER project:
- Locate your conversion utilities folder and double-click P330XERConvert.exe (If you changed the default installation folder, you will have to locate the file in the location you selected.)
- In the SDEF to XER Project Conversion dialog, choose SDEF as the conversion type, then click Next.
- Click Browse to select the SDEF file you want to convert, then click Next.
- Click Browse to select the XER file you want to overwrite or enter a new XER filename, then click Next.
- Click Finish.
- In the P6 client, choose File, Import. Follow the wizard prompts to import the XER file.
For specific instructions on importing XER files refer to the P6 client help.
Once the file is imported, the project is accessible using a P6 client.
