Working with WBS Categories
Use the WBS Categories page to define custom work breakdown structure (WBS) categories. Categories are not project-specific; you can assign them to any WBS elements in the EPS. WBS categories help reflect your organization's terminology and unique requirements. You can also use categories to group, sort, and filter WBS elements.
This illustration is a graphical representation of the text in the following table.
Table of WBS Category Administration
Item
Description
item one
Category field: The Category field shows the name of the WBS category. You can edit this value.
item  two
WBS Categories: Use the WBS Categories page to view and add WBS categories. This page is part of the Enterprise Project Data for your organization.
Table of WBS Category Assignment
Item
Description
item one
Activities page: On the Activities page, use the General detail window to select the WBS category you want to assign.
item  two
General Detail Window: In the General detail window, you can assign a WBS category by clicking in the WBS Category field. If the WBS Category field is not visible, click Columns and choose WBS Category. The category you assign helps organize the WBS element within the project. For example, a WBS category called Design would indicate that this WBS will focus on design tasks.
item  three
Select WBS Category dialog box: Use the Select WBS Category dialog box to assign a WBS category. You can select only one category. If you are assigning a WBS category to a parent WBS, you will be asked if you also want to assign that category to the child WBS elements. Choose yes or no as needed.
Related Topics
Creating WBS Categories
Copyright © 1999, 2024
Last Published Thursday, July 25, 2024
