Leveling Project Resources
Level one or more projects whenever the required shared or critical resources have limited supply or availability or to generally keep resource usage at a constant level. For example, when a resource has been assigned to more than one activity during the same time period, level the projects to eliminate potential resource over-allocation. Once you have performed resource leveling against your project or projects, you will be able to see where resources are overallocated and make decisions about whether work assigned to some resources should be redistributed to other available resources.
To level resources in one or more projects:
  1. Click Projects.
  2. On the Projects navigation bar, click Activities.
  3. On the Activities page:
    1. Click Actions and select Leveler.
    2. In the Level Resources dialog box:
      • Configure resource leveling options.
      • Select the Resources tab to specify which resources should be leveled.
      • Select the Prioritization tab to specify which assignments are leveled first when a conflict exists.
      • (Optional) Click Save to save your settings and close the dialog box.
      • Click Level Now.
Tips
Related Topics
About Resources
Assigning Resources to an Activity
Assigning Resources to Multiple Activities
Configuring Activity Resources
Adding Activity Resource Estimates
Specifying Resource Assignment Rates
Assigning Resource Curves to Resource or Role Assignments from the Activities Page
Assigning Resources to Unstaffed Activities
About the Recalculate Assignment Costs Feature
Configuring Resource Leveling Options and Priorities
About the Check Resource Overallocation Service
Creating Project Scheduled Services
Copyright © 1999, 2024
Last Published Thursday, July 25, 2024
