Configuring P6 Team Member View Preferences
Configure the Team Member view preferences to enable users to view and update the fields that are important for statusing the project in P6 Team Member Web, P6 for Android, or P6 for iOS.
To configure view preferences:
  1. Click Projects.
  2. On the Projects navigation bar, click EPS.
  3. On the EPS page:
    1. Select a project or EPS node.
Notes:
  1. Click Row Actions and select Set Project Preferences.
  2. In the Project Preferences dialog box, click Team Member then click the Status Updates tab.
  3. On the Status Updates tab:
    • Choose whether you want team members to provide status at Assignment Level, Activity Level, or both.
    • If you selected the Activity Level option choose whether you want team members to provide status As Owner or As Primary Resource. Select the As Owner option if your team members are assigned Team Member work distribution filters.
    • Click Add to add an Assignment Field or Activity Field and select the field you want team members to use to update their activities. Users assigned Team Member work distribution filters update Activity Fields.
    • Choose whether you want team members to update Additional Time Spent or Total Time Spent when updating actual units.
    • Select whether you want Team Members to be able to see Planned units, Baseline dates, and Total float.
    • Choose whether you want team members to update status in P6 Team Member Web Timesheets view by changing Percent Complete or Remaining Units.
    • Choose whether you want primary resources to be able to mark activities as complete.
    • Choose whether you want primary resources to be able to update activity dates in timesheets.
  4. On the Activity Updates Tab:
    • Select the Assign themselves to activities option if you want to allow team members using P6 Team Member Web, P6 for Android, or P6 for iOS to add themselves to activities.
    • Select the Outside assigned OBS access option if you want to allow team members using P6 Team Member Web, P6 for Android, or P6 for iOS to add themselves to activities even if the resource does not have access to the relevant OBS for the activity.
    • Select the Add and delete steps option if you want to allow team members using P6 Team Member Web, P6 for Android, or P6 for iOS to add and delete their own steps.
    • Select the Update notebooks option if you want to allow team members using P6 Team Member Web, P6 for Android, or P6 for iOS to be able to update notebook topics.
    • Select the Status other resource assignments on an activity option if you want to allow team members using P6 Team Member Web who are assigned as the activity owner, primary resource or who have been assigned Team Member work distribution filters, to update other resource assignments on the activity.
    • Click Add Code or UDF and select a global activity code, EPS activity code, or a UDF that should be visible to team members. The Read-only option next to each code and UDF is selected by default. If you want team members to update the code or UDF value clear this option.
    • Click Save and Close.
Tips
Related Topics
P6 Team Member Interfaces
How to Work with P6 Team Member Interface Users
About P6 Team Member
Getting Started with P6 Team Member Applications
About Team Member Work Distribution Filters
About Timesheets
About P6 Team Member Status Updates
About Email Statusing Service
About Discussions
P6 Team Member Interface Field Names
Copyright © 1999, 2024
Last Published Thursday, July 25, 2024
