Creating Baselines
Create baselines to measure project performance.
To create a baseline:
  1. Click Projects.
  2. On the Projects navigation bar, click Activities or EPS.
  3. On the Activities or EPS page
    1. Click the Actions menu and select Define Baselines....
    2. In the Define Baselines dialog box:
      • Select the project to which you will add the baseline.
      • Click Row Actions and select Add.
      • Enter a name in the Baseline Name field.
      • Select a type from the Baseline Type list.
      • Click Save.
Tips
Related Topics
About Baselines
Working with Baselines
Copyright © 1999, 2024
Last Published Thursday, July 25, 2024
