To set your User Productivity Kit (UPK) settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Application/User Productivity Kit.
- Select Enable User Productivity Kit to allow tutorials to be available within P6 EPPM.
Note: See the documentation included with Oracle UPK (User Productivity Kit) for details on In-Application Support.
- In the User Productivity Kit URL field, enter the URL used to launch UPK content.
Notes:
- The URL might be case-sensitive, depending on your application server configuration.
- WebLogic requires that the name of the UPK file stay the same when a custom UPK file is deployed. If you change the file name, you must create a new domain in WebLogic to match the name of the new UPK file.
- A UPK URL entered here is used for both P6 and P6 Team Member Web. A separate P6 EPPM configuration must be made to use different content in these products.
