Configuring Username Token Profile Settings for P6 EPPM Web Services
To set your Username Token Profile settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Web Services/Security/Authentication/Username Token Profile/Nonce.
    1. Select Require Nonce to enable nonce.
      Nonce is a token that contains a random value and is used to prevent attacks.
    2. In the Nonce Cache Timeout field, enter the value for the Nonce cache timeout. The value specified indicates how long the nonce remains cached before it is deleted.
      The default value is 10m.
      Enter a value between 5m and 24d.
    3. Select Require Created to enable the Username token timestamp.
      Requiring a Created element allows the server to determine whether the difference between two timestamps falls within an allowable window of time and can then reject any messages that exceed the window.
    4. In the Timeout field, enter the value for the Created timestamp timeout. You can specify a minimum of 5m.
Related Topics
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring Authentication Mode for P6 EPPM Web Services
Configuring SAML Token Profile Settings for P6 EPPM Web Services
Configuring Message Protection Settings for P6 EPPM Web Services
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
