Configuring Import/Export Service in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you have store period performance work that needs to be done immediately, you should set the Interval low (for example, 10s) and the Concurrent Threads high (for example, 20). Remember that if the server is actively running store period performance work, all users will experience delays in the application.
To set your store period performance settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Services/Job Services.
  4. Select Import/Export.
  5. Under Import/Export Service:
    1. In the Interval field, enter the amount of time the service will wait before running the next available job (in 1d1h1m1s format, specifying only numbers without letters implies milliseconds).
      The default value is 10s.
      Enter a value between 1s and 24d20h31m23s647.
    2. In the Concurrent Threads field, enter the number of processes used for the service on this server. A value of 0 indicates that the service is not available on this server.
      The default value is 2.
      Enter a value between 0 and 20.
    3. In the Active Mode field, select true if you want jobs processed continuously until all jobs finish. Select false if you want each job processed according to the Interval.
Related Topics
Configuring Import/Export Options in Services Settings
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
