The Global Access tab in the Users dialog displays the selected user's resource access settings. The same settings can be displayed as columns as well. To view resource access information, add the Resource Access and All Resources Access columns to display in the Users dialog box. These columns are not displayed by default.
- All Resources Access
 The All Resource Access column displays a checkbox for each user. If the checkbox is marked, the user has access to all resources. This option disables resource security.
 This column is available only for users with all resource access or Admin Superusers.
- Resource Access
 The Resource Access column displays the user's assigned nodes. The user has access to these resource nodes and all their children.
 If the Resource Access column is empty and the All Resources Access checkbox is unmarked, the user has no access to any resources.
