Create a financial period (P6 Professional Only)
If the duration of your organization's financial periods is not consistent, you can create individual financial periods. You should create a batch of financial periods when each financial period will have the same duration (for example, two weeks, one month, three months, etc.) over an extended period of time.
  1. Choose Admin, Financial Period Calendars.
  2. Select a financial period calendar and click Modify.
  3. In the Financial Periods dialog box, click Add.
  4. In the Select Financial Period Timescale dialog box, enter or select the period Start Date and End Date.
  5. Click Add.
    The Select Financial Period Timescale dialog box remains open. You can add additional financial periods by repeating steps 4 and 5.
  6. When you have finished adding financial periods, click Close.
    The financial periods you just created are listed in the Financial Periods dialog box.
Tips
Notes
Related Topics
Create a batch of financial periods (P6 Professional Only)
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
