Export resources for use with Oracle Primavera Contractor
You can export the resource dictionary in P6 Professional project to XER format, then import the XER file to Oracle Primavera Contractor 5.0 or 6.1 or later. You cannot import an XER file to an earlier version of Oracle Primavera Contractor than 5.0.
  1. Choose File, Export.
  2. Choose Primavera Contractor - (XER).
  3. Select the appropriate version from the pull-down menu. Click Next.
  4. Choose Resource Only. Click Next.
  5. Type or select the name of the export file and the location where the file will be saved.
  6. Click Finish.
  7. Click Close.
Note
Copyright © 2018, 2023
Last Published Thursday, January 12, 2023
