Adding resources using a wizard
Resources include the personnel and equipment that perform work on activities across all projects. You can create a resource pool that reflects your organization's resource structure and supports the assignment of resources to activities.
If the Use New Resource Wizard checkbox is marked in the User Preferences dialog box, the New Resource Wizard displays each time you add a resource to guide you through the process.
Related Topics
Set wizard options
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
