When you assign a default tracking layout to an issue, you can quickly view issue details through the Issue Navigator.
- Choose Project, Issues, then select the issue.
- Display Issue Details, then click the General tab.
- In the Tracking Layout field, click  , select the tracking layout you want to assign, then click the Select button. , select the tracking layout you want to assign, then click the Select button.
