Assign Access to OBS dialog box
Use the Assign Access to OBS dialog box to enable the selected user to access project data for the EPS and WBS elements related to a specific OBS member.
Display Options bar: Lists options for changing the organizational breakdown structure (OBS) display.
OBS Name: Lists the organizational breakdown structure (OBS). To sort the display, click the OBS Name column label.
Assign: Assigns the selected OBS element to the Project Access list.
Remove: Removes the selected OBS element from the Project Access list.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
