Assign Activity Codes dialog box
Use the Assign Activity Codes dialog box to assign an activity code to the selected activity. You can also use this dialog box to create and assign a new activity code value.
Global: Click to display global activity codes.
EPS: Click to display EPS-level activity codes.
Project: Click to display project-specific activity codes.
Display Options bar: Click to change the activity code values display.
Search: Type an activity code or description to display a filtered list of activities whose ID or name begins with this value.
Activity Code Value: Lists code values according to activity code. To sort the display, click the Code Value column label.
Description: Describes each activity code value. To sort the display, click the Description column label.
Assign: Assigns the selected activity code value to the selected activity.
Remove: Removes the selected activity code value from the selected activity.
New: Click to create a new activity code value. You can then assign the new value to a selected activity. This icon is disabled if no code band is selected or if you do not have security to edit the selected type of activity code (global, EPS, or project).
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
