Chart Box Template dialog box
Use the Chart Box Template dialog box to customize chart box content and appearance when you view information in the Activity Network.
Sample Box: Shows the data elements selected for the box, in the order in which they will appear in the box.
Field Name: The name of a data element included in the box.
Width: The width of a data element included in the box.
Height: The height of a data element included in the box.
Total Width: The total width of all data elements included in the box.
Add: Adds a data element to the box.
Delete: Deletes the selected data element from the box.
Shift Up: Shifts the selected data element up.
Shift Down: Shifts the selected data element down.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
