Create a filter
  1. Choose Project, Activities, then choose View, Filter By, Customize.
  2. Click New, then type a filter name.
  3. Click the Parameter field and select a data item.
  4. Double-click the Is field to select a filtering criteria. Specify a value in the Value field.
  5. To add multiple criteria to the filter, click Add. In the new row, click the Parameter field and select a value. Double-click the Is field and select a filter criteria. Specify a value.
    To review your filter criteria to eliminate redundancy, from the Display Options bar, choose Optimize.
  6. When you are finished specifying filter criteria, click OK.
Notes
When connected to a P6 EPPM database: If you are filtering by unit or duration field and the Use assigned calendar to specify the number of work hours for each time period checkbox is cleared (Application Settings, Time Periods link in P6), then filtering applies the unit or duration value based on the Application Settings, Time Periods link, Hours per Time Period in P6.
If the checkbox is marked, then filtering applies the unit or duration values as follows: For a task-dependent activity, duration or unit values are applied based on the applicable global or project calendar; for a resource-dependent activity, duration or unit values are applied based on the resource calendar.
Tip
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
