Create  EPS-level activity codes
 - Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Click Add to select the EPS to which you want to add the activity code.
- In the Activity Code Name field, type the name of the EPS-level activity code.
- In the Max Length field, specify the maximum number of characters for the activity code's values.
- Click Close.
Tip
 - To change the order in which EPS-level activity codes are listed, select the activity code you want to move in the Activity Code Definitions dialog box, then click Shift Up or Shift Down.
