You can customize the columns that display in the left pane of the Activity Usage Spreadsheet.
- Display the spreadsheet, then choose View, Columns.
- To add a column to the spreadsheet, select it in the Available Columns section, then click  . .
- To add all available columns to the spreadsheet, click  . .
- To remove a column from the spreadsheet, select it in the Selected Options section, then click  . .
- To remove all current columns from the spreadsheet, click  . .
 You must select at least one column to display in the spreadsheet.
- To change the order in which columns display, in the Selected Options section, select a column you want to move:
 To move the column left, click . .
 To move the column right, click . .
- To update columns in the spreadsheet, click OK, or to view your changes without closing this dialog box, click Apply.
 To restore the default columns, click Default.
