- Choose Enterprise, Cost Accounts.
 Click the Cost Account ID column label to display the cost accounts hierarchy. An outline symbol in the Cost Account ID column label indicates a hierarchy display.
- Select the cost account you want to cut and paste, then click Cut.
- Select the cost account to which you want to add the cut account, then click Paste.
Note
- When you cut and paste a cost account, the account's activity and project assignments are also pasted.
