Cut, copy,  or paste a statement
 - Choose Tools, Global Change.
- Select the global change specification you want to edit, then click Modify.
- Select the statement you want to cut or copy, then click either Cut or Copy.
- Click the section into which you want to paste the statement.
- Click Paste.
 The new statement is placed at the bottom of the list of statements.
Note
 - You cannot paste statements from the If section of the Global Change dialog box into the Then or Else sections; however, you can cut or copy and paste between the Then and Else sections.
