Display work product and document details in the Activities window
- Choose Project, Activities.
- Select an activity associated with the document.
- Display Activity Details, then click the WPs & Docs tab.
To display the WPs & Docs tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select WPs & Docs, click
, then click OK.
- Select the work product or document, then click Details.
To view the work product or document, click Launch next to the appropriate Location field.
Note
- Only P6 Professional users can open private location documents. Public location documents can be viewed by all project participants.
Display window details
