Use the Edit Font & Color dialog box to change the color and font used to indicate grouping levels in the current display.
Font: Allows you change the selected grouping's font.
Color: Allows you to change the selected grouping's color.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
