- Choose Enterprise, Activity Codes.
- Choose Global.
- Select the activity code whose value you want to change.
 To change a value name or description, double-click the item you want to change, then type the new text.
 To change the placement of the code in the list, click Shift Up or Shift Down.
- Click Close.
Tip
- If you change an activity code value, your changes apply to all activity assignments.
