The module automatically reorganizes data in the current window according to the group and sort criteria specified for the window when you add or move data, unless you disable auto-reorganization. Do one of the following:
- With any window active, choose Tools, Disable Auto-Reorganization.
- Click  on the Tools toolbar. on the Tools toolbar.
Tips
- By default, Disable Auto-Reorganization is turned off, meaning that window data will be automatically reorganized unless you turn this feature on.
- A square outline surrounding the icon on the menu or in the toolbar indicates that Auto-Reorganization is currently disabled.
- Auto-reorganization applies to window-level data only; it does not apply to data stored in dialog boxes. For example, activities in the Activities window may be reorganized using this feature, but related elements in an associated dialog box will not be reorganized, even if Disable Auto-Reorganization is turned off.
- When you change views, apply a filter, cut, copy, paste, or refresh data, P6 Professional will reorganize the data, regardless of whether Disable Auto-Reorganization is enabled or disabled.
- Your auto-reorganization setting (enabled or disabled) applies to the active window only.
