External Applications dialog box
Use the External Applications dialog box to set up links with external applications. The External Applications dialog box displays the following fields:
Project ID: Select the project that you want to link to an external project.
Application Name: Choose the name of the external application. Each application can be linked once per project.
External Project Name or Identifier: Type the name of the external project you want to link to your project.
Add: Adds a new external application link.
Delete: Deletes the selected link.
The External Applications dialog box contains the following tabs:
Related Topics
General tab - External Applications dialog box
Login tab - External Applications dialog box
Data tab - External Applications dialog box
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
